Removal Procedure
Tools Required
J38197 Crankshaft Balancer Puller
J37096 Flywheel Holding Tool
J36660-A Torque Angle Meter
Remove the drive belt. Refer to Drive Belt Replacement.
Remove the right front tire and wheel. Refer to Tire and Wheel Removal and Installation.
Use the J37096 in order to hold the flywheel.
Remove the balancer bolt.
Important: Do not separate the pulley from the balancer. Service the pulley and the balancer as an assembly.
Use the J38197 in order to remove the crankshaft balancer. Attach 1/4 in. bolts to the pulley. Screw the bolts in 1/4 in.
Sep 21, 2010 at 4:19 PM
