2000 Buick Park Avenue NOT GETTIN FUEL TO THE ENGINE
HALEGU
Engine Performance problem
2000 Buick Park Avenue 6 cyl Two Wheel Drive Automatic
i HAVE CHECK THE REGULAR FUSE AND ITS FINE. IS THERE A WAY TO CHECK THE RELAY? THE CAR JUST SHUT OFF. THEN WHEN YOU TRY TO CRANK IT , NOTHING.
AFTER TOWING IT HOME, WILL TURN OVER BUT NO FIRE.
Nov 11, 2008 at 1:02 PM
BMRFIXIT
  • 19,053 POSTS
Check for spark and fuel pressure
no fuel suspect fuel pump
no spark suspect crank sensor
check if security light on and blinking
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 11, 2008 at 10:26 PM
