Engine Mechanical problem
2000 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 190K miles
I just changed the engine the Buick Ulta with a supercharged 3.8 because the old supercharged 3.8 was making noises in the bottom end. I am not able to get the new motor to run. I here the fuel pump run but am not getting fuel in the cylinders. The car turns over but never fires. The spark plugs are dry, I changed map sensors with the old motor hoping that was it but it didn't help. What should I do next?
Thanks,
Thanks,
Jul 19, 2009 at 11:21 AM
