2000 Buick Park Avenue electrical
2000 BUICK PARK AVENUE
140,000 MILES • 6 CYL • FWD • AUTOMATIC
RCMIKE
hello the sunroof does not work only the driver power seat not work radio door locks fuses good could this be main ground and if it is can you tell me where it is
Nov 3, 2010 at 11:33 PM
JDL
  • 16,098 POSTS
If the power seats don't work, check the power seat circuit breaker, use a voltage tester, check for voltage. You may need to get at the power seat motor and check voltage there. In the diagram, the ground shows to be at the right kick panel.
https://images.2carpros.com/forum/automotive_pictures/170934_park_avenue_power_seats_1.jpg
Nov 4, 2010 at 2:28 AM
