2000 Buick Park Avenue driver side front and rear floor boa
2000 BUICK PARK AVENUE
TMAJ9447
  • 78 POSTS
Air Conditioning problem
2000 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 98k miles
Hi all,
Here is the deal, i unclogged the weap hole from underside fire wall. Got soaked while doing it so i thought the problem was solved. yet 1 week later still getting wet floors.
Please help with what i can do and instructions how 2 please.
Thanks a lot guys!!!
Jul 21, 2010 at 12:19 PM
  • 110,244 POSTS
Is there warter running out of the drain when you use the AC?
Jul 21, 2010 at 2:14 PM
TMAJ9447
  • 78 POSTS
yes, there is water draining out the drain now. athough the floors are still getting wet.
Jul 21, 2010 at 4:27 PM
  • 110,244 POSTS
Under the dash is where the heater core, AC... are located. They are enclosed in plastic. There is either a crack or a leak coming from there allowing some of the water to remain in the vehicle. I hate to say it, but you need to craw under the dash and start looking. I wish there was an easier way, but that is it.
Jul 21, 2010 at 5:52 PM
TMAJ9447
  • 78 POSTS
Okay,
after a long day of disassembly, i removed the carpet and found that the carpet had apporx 2.5 gallons of water absorbed into the foam. i ran the car with out the carpet and found no more leaks. so problem solved and carpet is now dry.
thank you for your support!
Jul 22, 2010 at 11:40 AM
  • 110,244 POSTS
Glad to help. That is a lot of water. Let us know if you have questions in the future, and thanks for using 2carpros.com
Jul 22, 2010 at 4:54 PM
