2000 Buick Park Avenue bank one
2000 BUICK PARK AVENUE
140,000 MILES • 6 CYL • FWD • AUTOMATIC
04MRP194617
read out says bank one is lean i have changed plugs, plug wires installed new sensors but still missing when idling after trying it the light comes back on reading lean bank one still.
Feb 1, 2010 at 3:58 AM
Lean condition:
Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Feb 1, 2010 at 4:05 AM
