2000 Buick Park Avenue 2000 buick park avenue ultra stutter
2000 BUICK PARK AVENUE
90,000 MILES • 6 CYL • FWD • AUTOMATIC
MCNEW704
ok last week my car started stuttering while accelerating. Idle the cars purrs like a kitten no stutter if u mash the pedal it will speed up but it stutters onced leveled off its fine but if u try to accelerate like from 45 to 55 it stutters like its missing now i checked and cleaned maf also i checked coil pack and the 2 coil pack was a little rusty so i just replaced the car was tuned up maby 3 months ago wires plugs cleaned injecters not sure whats wrong someone please help also i forgot to add it dosent make the service engine soon light come on it did once and it flashed on and off then went off and problem is still there like i sadi crusing like 35-45 even to 75 steady is fine but when you accelerate it studders
Feb 9, 2010 at 12:06 PM
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 9, 2010 at 3:06 PM
