1999 Buick Park Avenue speed sensor
ANGELLADY
Transmission problem
1999 Buick Park Avenue 6 cyl Automatic 163000 miles
My check engine light goes off often. When it does it seems as if the transmission hesitates switching gears. When I decelerate, it downshifts very hard & I can feel this toward the rear of the car. I did a diagnosis & was told it's a speed sensor. Where is the speed sensor located? Is it on the inside or the outside?
Aug 6, 2010 at 2:40 PM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1999_buick_park_ave_speed_sensor_part1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1999_buick_park_ave_speed_sensor_part2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1999_buick_park_ave_speed_sensor_part3_1.jpg
First of all thank you so much for your donation.It's located on the transmission i posted a diagram of where it is and how to change it for you.
Aug 6, 2010 at 4:59 PM
ANGELLADY
[quote:2b1997f12e="angellady"]Transmission problem
My check engine light goes off often. When it does it seems as if the transmission hesitates switching gears. When I decelerate, it downshifts very hard & I can feel this toward the rear of the car. I did a diagnosis & was told it's a speed sensor. Where is the speed sensor located? Is it on the inside or the outside?[/quote:2b1997f12e] Ok so the shop I took my car to said the tranny needs to be disconnected, is this so? He did say speed sensor, if its not, what sensor is in the tranny that would need replacing?
Aug 7, 2010 at 4:57 AM
SATURNTECH9
  • 30,869 POSTS
I gave you the information for the output sensor that's what people call the speed sensor.Now the input speed sensor is inside the transmission.If you can tell me the exact name of the sensor they are talking about changing i can tell you more.Call and ask them then post the information so i can give you the correct information.
Aug 7, 2010 at 5:38 AM
ANGELLADY
Well I guess it is the input sensor the codes that came up he said was p0716 & 717, do you have a diagram for changing that one? There were 2 other codes that came up as well, p1546 & p1602, my air conditioning isn't working so what could this be? Can you please explain these other 2 codes? Thanks so much!!
Aug 7, 2010 at 8:42 AM
SATURNTECH9
  • 30,869 POSTS
I emailed you how to replace the input speed sensor.The labor for replacing the input speed sensor is 4.1hrs times what ever the shop labor rate is 80-100 per hr?Plus alignment 60-100.For your other two code's i need to know what the 8th digit of your vin is?The transmission's are same for both engine's but i need to know what the 8th digit of your vin is so i can get you the correct info.I think it has something to do with your a/c.
Aug 7, 2010 at 5:52 PM
ANGELLADY
Louie, could you please re-email me the instructions on changing the input sensor? I didn't receive anything. As far as the other code, this isn't the original engine, does that matter? Thanks!
Aug 8, 2010 at 1:50 AM
SATURNTECH9
  • 30,869 POSTS
You should have gotten it is the email address on this site current?Also as long as they put the same engine back in when they replaced it then giving me the 8th digit of the vin should be fine.
Aug 8, 2010 at 9:48 AM
