1999 Buick Park Avenue removal of leveling system compresso
177,000 MILES • 6 CYL • FWD • AUTOMATIC
MDGIBBONS
  • 10 POSTS
I have a 99 park ave that I recently disconnected and removed the compressor to the leveling system to the rear suspension.
My question is, since the unit is no longer on the car, but I have taped up the wiring plugs with electrical tape, will this cause problem with a loose ground?
My lights are flickeing when the car is running.
Michael Gibbons
Mar 19, 2009 at 6:00 AM
ZACKMAN
  • 4,202 POSTS
If the wiring harness is taped up so it won't move around, then it is not your problem. You need to take the vehicle your local auto parts store and have them check the electrical system: battery, starter, and alternator. Just to be sure that your battery is in good condition, and your alternator is giving enough charge to run the motor and all of your electrical system.
Mar 19, 2009 at 1:44 PM
MDGIBBONS
  • 10 POSTS
Zach,
Thanks for the help. I did have the alternator and battery checked out and they were okay. I am going to go ahead and have the electrical system checked out also.
I will let you know when I find out.
Michael
Mar 20, 2009 at 2:57 AM
