1999 Buick Park Avenue Reading codes
151,000 MILES • 6 CYL • FWD • AUTOMATIC
CHFNELSON
There is a method of reading codes by jumping two terminals of the diagnostic connector with a paper clip. My diagnostic connector does not have terminals in the two ports refernced. What ports should I use?
Nov 24, 2009 at 4:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you can not jumper the DLC on your vehicle..you MUST use a Tech 1 or Tech 2 scan tool to perform a OBD (on-board diagnostic) system check.
Nov 24, 2009 at 5:08 AM
