1999 Buick Park Avenue Crankshaft position sensor
1999 BUICK PARK AVENUE
209,000 MILES • 6 CYL • FWD • AUTOMATIC
GGORM
I replaced the crankshaft position sensor and the car ran fine. Now it is back to doing what it was doing. Starts up fine runs then shuts off. I took the car on a 400 mile trip and the car ran good.
Nov 10, 2009 at 9:46 AM
  • 110,194 POSTS
Has the check engine light come on again?
Nov 25, 2009 at 9:32 AM
GGORM
No the check engine light has not come on again.
Nov 25, 2009 at 9:56 AM
  • 110,194 POSTS
If the light hasn't come on that makes it tough. It could be that you have a crank sensor that is going bad again, an ignition module... Has the fuel pump pressure been checked?
Nov 25, 2009 at 11:33 AM
GGORM
We replaced the fuel filter yesterday. But before that we disconnected the fuel pressure increase valve and the didn't shut off.
Nov 25, 2009 at 11:38 AM
  • 110,194 POSTS
Are you refering to the regulator? Also, how much pressure was the pump producing?
Nov 25, 2009 at 11:43 AM
GGORM
We are going to check that soon, how much should it produce? What is the best way to test the crankshaft position sensor?
Nov 25, 2009 at 11:57 AM
  • 110,194 POSTS
THe fuel pressure should be between 48 and 55PSI. Here is a how to for checking it and the fuel pressure regulator:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
As far as the crank sensor, you will need a volt meter. Set it to AC voltage output. Connect it to the sensor and crank the engine. The sensor should generate a voltage signal of about 2 volts. Make sure you disconnect the output wiring except to your meter. Otherwise, the engine can start.
Please be careful doing this. Make sure to protect your hands, body...
Nov 25, 2009 at 10:41 PM
