1998 Buick Park Avenue replacing struts
MDSPARKS
Suspension problem
1998 Buick Park Avenue 6 cyl Two Wheel Drive Automatic
I replaced struts. I did not see any adjustment for camber. does that mean it is fixed and I don't need it aligned?
Mar 12, 2009 at 5:45 AM
MERLIN2021
  • 17,250 POSTS
This is for NON electronic suspension.
"E" & "K" Body (Except Seville) Loosen nuts on bolts securing strut to steering knuckle. Tighten or loosen camber adjusting bolt as necessary to adjust camber to specification. See WHEEL ALIGNMENT SPECIFICATIONS table. While holding wheel in position, tighten nuts to specification. See TORQUE SPECIFICATIONS table. © 2008 Mitchell Repair Information Co., LLC. Page 1 of 1 WHEEL ALIGNMENT SPECIFICATIONS & PROCEDURES -1998 Buick Park Avenue 3/12/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx"E" & "K" Body (Except Seville) Support vehicle by its wheels (suspension loaded). Remove nuts and washers from front strut mounting tower. Move top of strut forward and/or rearward as necessary to adjust caster. See WHEEL ALIGNMENT SPECIFICATIONS table. Tighten nuts to specification. See TORQUE SPECIFICATIONS table. © 2008 Mitchell Repair Information Co., LLC. Page 1 of 1 WHEEL ALIGNMENT SPECIFICATIONS & PROCEDURES -1998 Buick Park Avenue 3/12/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx
Mar 12, 2009 at 5:58 AM
