1998 Buick Park Avenue gas gage lever
PETTIESRUBY
  • 1998 BUICK PARK AVENUE
Computer problem
1998 Buick Park Avenue 6 cyl Front Wheel Drive
I just trying to find out what I do to get the levar on the gas gage to come above the pin again like it use to be.
Sunday, September 12th, 2010 AT 4:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You mean the needle is on the wrong side of the gauge? If so try disconnecting battery and reconnecting it should reset the gauges.
Monday, September 27th, 2010 AT 5:50 PM
PETTIESRUBY
I tried disconnecting the battery for the gas gauge pin to be reseted, but unfortunely, I didn't get good results. I don't know what I should do know. Do you have any other idea's.
Wednesday, September 29th, 2010 AT 12:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You can try using a strong magnet to drag the needle around to the other side of the pin, if that doesn't work than the gauge will most likely need replaced.
Wednesday, September 29th, 2010 AT 1:15 PM
