Engine will not turn over
SHADB
I was flushing out my radiator. Before I replaced the coolant my little bad cousin went to my car and was trying to crank it. Now it will not even turn over when I try to crank it. I check the motor and it is not locked up. Does anyone know what the problem might be? Everything else work it just will not crank or even turn over now.
Mar 16, 2009 at 6:48 PM
BMRFIXIT
  • 19,053 POSTS
It sounds like the starter motor has gone out or you have a bad battery connection. Here is a guide to help you get started on checking for the problem:
If okay use a test light to test the small trigger wire and the starter to confirm the failure. Here is a guide:
If bad here is a guide to show you how to change the starter out:
Please let us know what you find.
Cheers
Mar 16, 2009 at 11:17 PM
SHADB
Thank you it was the starter. I got an AC Delco unit for $134.00 started right up.
Mar 18, 2009 at 3:32 AM
JULIE H.
I kept on having to get a jump. Now my car will not take a jump. I took my battery to AutoZone and they charged it fully and said there was nothing wrong. I put the battery in and tried to start it and it shut off. What could drain my battery instantly and not allow me to receive a jump? I was told the alternator or starter. Which one do you think it is?
Jul 19, 2018 at 8:30 AM (Merged)
  • 75,988 POSTS
Have the alternator load test and double check the battery connections.
No crank at all/nothing when key at cranking position. Do below:
Could be a blown fusible link, the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery condition and connections are good.
LANDRY
V8 front wheel drive automatic.
I Just wanted to know could it be my starter if my car does not turn over it does not say a word?
