1998 Buick Park Avenue Dash Board Removal
143,000 MILES • 6 CYL • FWD • AUTOMATIC
HYDEMSG
I have a 98 Park Avenue. On the instrument panel, the gas gauge needle and the coolent gauge needle are both below the little black stop. I assume the car got too hot and the needles bent and then fell below the stop pin on the gauge. How do u take apart the dash board? Can the plastic cover on the instrument panel be removed? Should I just dril small hole in panel and pull gauge needles up w a wire. Thank You
Aug 6, 2008 at 7:40 AM
HYDEMSG
[quote="HYDEMSG"]Interior problem
1998 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 143000 miles
I have a 98 Park Avenue 143,000 miles When I accelerate I get a short pause. It is even worse when the A/C is running. Any advice will be great. Can this be repaired.
Aug 8, 2008 at 4:47 AM
