Caliper bolts
GMOORE980
how do i take off the bolts to change the rear brake pads
Sep 28, 2010 at 12:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2716.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_882.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_321.jpg
Sep 28, 2010 at 1:48 PM
ANDREGRIFFIN
For the life of me I can't figure out how to remove the calipers on the rear disk brakes ( no visible screws) and everything seems to be attached to the caliper.
Sep 16, 2019 at 8:14 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
The first thing you want to do is check to see if the the parking brake is working . These calipers tend to bind up and become more of a nusence than anything. IF it were mine I'd put on calipers. In the northeast these calipers just can't handle the weather. Anyways, there are 2 pins that extend into the spindle. I remove the one that the arrow points to. Then pivot the caliper off the remaining post.
https://images.2carpros.com/forum/automotive_pictures/30961_97c_1.jpg
Also these pistons can't just be pressed in or it will break. They need to turn while being pressed. There is a special tool available. Follow the dots on this pic and you can see some v-grooves in the piston.
https://images.2carpros.com/forum/automotive_pictures/30961_97b_1.jpg
