1998 Buick Park Avenue ABS light
1998 BUICK PARK AVENUE
98,000 MILES • 6 CYL • FWD • AUTOMATIC
KURTSMITH
I drove through a 10" puddle of water and shortly after that when I stopped the brakes shuddered like the ABS was working even though the road was dry. Then the ABS and Traction Control Off lights came on. I waited a few days for things to dry out and the I removed the wheels and checked all the wiring. It all look fine. I removed the battery cable to reset any codes, the lites stayed out until I moved the car about 100 feet then they came on again. Any Ideas?
Feb 26, 2008 at 10:59 AM
ED ARMES
  • 129 POSTS
It appears that one of the speed sensors on one of the wheels has failed. These can be tested with an ohm meter but I do not know what those value parameters are.
You might also check the relucter rings they read off of for a damaged tooth. One tooth damaged is all it takes to alert the system to a problem.
Mar 13, 2008 at 1:30 PM
