1998 Buick Park Avenue
LAUREN.HELP
help is it common for the driver window to stop working? I can roll all the other windows down and up from drivers but not the drivers window itself guy i bought from said needed new switch got that got it put in by auto crash shop and still dont work? what should I do. Also the air conditioning works every vent but the two on the driver side. and the driver door handle broke on the outside i have to climb in from passaneger and then i can get out of drivers side what should i do what do i need to fix the problems all the car places say its one thing do it and it dont fix it???? please help
Mar 31, 2010 at 4:59 PM
  • 110,248 POSTS
The door handle is either disconnected or broken. As a result, you need to remove the panel and inspect it. As far as the window, while the panel is off, check to see if the window motor is working. See if it is getting power.
Let me know what you find.
Apr 7, 2010 at 1:50 AM
