1997 Buick Park Avenue Turn Signals
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAWUCK
The right turn signals and indicator on dash not working. Left signals working correctly. Right side bulbs work with the hazard switch. This is a 1997 Buick Park Avenue Ultra.
Jun 9, 2010 at 7:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely culprit is turn signal switch but check wiring to switch first
Jun 9, 2010 at 7:55 AM
JAWUCK
[quote:37c4ae3946="bluelightnin6"]most likely culprit is turn signal switch but check wiring to switch first[/quote:37c4ae3946]
Thank you for quick comeback. I will do that. I disconnected the battery to reset computer but that did not help.
Jun 9, 2010 at 8:13 AM
