1997 Buick Park Avenue serpentine belt
1997 BUICK PARK AVENUE
TAZWOLF
Engine Cooling problem
1997 Buick Park Avenue 6 cyl Two Wheel Drive Automatic
it seems that the front motor mount does not have enough clearance to be removed from the frame rail and one on the bolts to remove the engine bracket is behind a pully??? it says it's a 1.5 hour job. I'm missing something? the manual says just remove the motor mount and replace the belt! The belt must run inside and outside of the motor bracket so how can it go on with out removing the motor bracket??? I must be missing something simple, HELP I'm supposed to have the car returned tomorrow by 10 Tazio
Feb 12, 2009 at 1:08 AM
ZACKMAN
  • 4,202 POSTS
