1997 Buick Park Avenue p0300
1997 BUICK PARK AVENUE
86,235 MILES • 6 CYL • 2WD • AUTOMATIC
EDCOVE
I had a p0302 and the plug was done. I replaced the plug and get p0300. I replaced all plugs, they were toast. I also replaced wireset, it was oem and two of the wires resistance was marginal. I have check each coil pack, primary and secondary side, and all readings are within specs. Still throws P0300 consistantly.
Mar 19, 2008 at 1:24 PM
BLACKOP555
  • 10,386 POSTS
hows the ignition timing look?
when you changed the wires you didn't mix up the ignition wire order did you?
Mar 19, 2008 at 2:45 PM
