1997 Buick Park Avenue massive vaccumethrough oil fill hole
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENTLOVIN
my car pull a big vaccume through the oil fill when car is running it also runs rough when the cap is off smooths out when closed
Mar 8, 2010 at 1:42 AM
  • 110,248 POSTS
THat is normal if the PCV is working properly. It is designed to suck out pressure in the crankcase. If you open it, you create a leak. If the pressure was blowing out, that would not be good.
Mar 19, 2010 at 5:04 AM
