1997 Buick Park Avenue How to remove inside door panel to f
189,000 MILES • 6 CYL • FWD • AUTOMATIC
KEMOCK
I need to know how to remove the door panels from the inside or interior to access the "guts" inside the door to fix the tracking on the window and to fix the exterior door knob where a bolt or cotter pin cam unhooked and the door will not open from the outside.
Aug 3, 2010 at 4:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
first you have to pop off the latch thats located inside the drivers side armrest. There should be 2 screws their. Finding the last screw was the problem for me. You have to take something like a screwdriver and pop off the interior light on the door and their you will find the last screw. After that it should pop right up. I think there is also a push pin type retainer inside the vent feed hole
Aug 3, 2010 at 4:18 PM
