1997 Buick Park Avenue ENGINE STUTTERING
222,000 MILES • 6 CYL • FWD • AUTOMATIC
KELMASELL
stutters at certain speeds not all the time
sometimes RPM meter goes to zero and will not come back until I restart engine
Engine dies driving on highway
sometimes does not start
Jul 22, 2009 at 1:43 AM
JMALECKI
  • 118 POSTS
Hello
Sounds like you may have a module problem, if you remove the module most of the larger parts stores can test them, call first to be sure they can check your particular module before going there also if they can have them check 3 or 4 times, modules usually fail when they get hot and it may take that many times to show up.
John
Jul 28, 2009 at 2:37 PM
