1997 Buick Park Avenue air flow problem
1997 BUICK PARK AVENUE
11,300 MILES • 6 CYL • FWD • AUTOMATIC
KCIUB
fan motor runs, but no air flow
I changed the filter( there are three on my car) a week or 2 ago, the heater has worked since changing the filter.
Thanks, Dan
Oct 15, 2009 at 1:15 AM
OBXAUTOMEDIC
  • 3,711 POSTS
When was the last time you changed the Cabin Air Filter? If you haven't or didn't even know you had one then that is most likely to cause of the no air flow.
The filter is located next to the Gas Pedal. I believe there are 2 on your vehicle and they are in the same place.
Oct 15, 2009 at 2:46 AM
