1996 Buick Park Avenue Engine power loss
BUBASMTH
1996 Buick Park Avenue 6 cyl Two Wheel Drive Automatic
Car does not respond to throttle input after it gets up to speed. Cruise won't even respond if you touch the brakes then hit resume. Just seems as if the engine has no power to pick up speed to pass or resume with cruise engaged. Thinking it may be the mass air flow sensor, possible fuel filter or even that the catalytic converter may be plugged. Any help would be appreciated.
Nov 22, 2009 at 1:24 AM
  • 110,248 POSTS
Has the check engine light come on? Also, have you checked the fuel pressure?
Nov 24, 2009 at 10:41 PM
