1996 Buick Park Avenue coil pack
KOZMICGIRL
Engine Performance problem
1996 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
Could you tell me what order does the coil pack suppose to go. is 1-4, 5-2,3-6 could you tell if that is right.
Jun 1, 2008 at 9:19 AM
  • 31,937 POSTS
Hi there,
I have the same job on the hoist as i type this, yes they are a problem. The pumps are prone to leaking and are a sealed unit and can't be kitted. Steering boxes are expensive to o/haul but price will normally depend on what is wrong with it.
Mark (mhpautos)
Jun 17, 2008 at 12:44 PM
BLKFTHR
Thank you for the prompt reply. Should I assume then that if there is any leaking, it would be a waste of time to have the steering box "adjusted", and that I should replace it? If so, what would be an average cost-parts and labor? Thanks again!
Jun 17, 2008 at 2:22 PM
  • 31,937 POSTS
Hi there,
You will not resolve the leaks with any adjustments, so the box will have to be O/Hauled. As for price i can't give you a realistic price just now as i am in Australia. I can access the US data base later this evening (my time) and then i should be able to give you a better idea.
Mark (mhpautos)
Jun 17, 2008 at 2:39 PM
