1996 Buick Park Avenue blown fuse
200,000 MILES • 6 CYL • FWD • AUTOMATIC
SIRRONH
fuse block behind glove box blows fuse for a/c (hence blowing warm air) and check engine oil light comes on, but oil level is fine. Thought sending unit was bad, but when i unplugged it, the light still comes on and fuse keeps blowing. Any ideas?
Aug 19, 2010 at 10:30 AM
WRENCHTECH
  • 20,760 POSTS
Does that light actually say check oil level? Are you sure it isn't an oil PRESSURE light instead?
Aug 19, 2010 at 11:00 AM
SIRRONH
Yes sir, it actually says check oil level. I have replaced the fuse and am going to drive the car for a while w/o the air on and see if the fuse blows
Aug 19, 2010 at 1:41 PM
WRENCHTECH
  • 20,760 POSTS
The sensor is probably bad. You can replace it when you do the next oil change.
There's a good chance that the compressor coil is what's blowing the fuse. You can try unplugging it and turning the rest of the system on to see if that's the case.
Aug 19, 2010 at 1:44 PM
SIRRONH
While driving the car, the fuse blew before the air had ever been turned on. I'm not sure if the fuse blowing triggers the light or vice-versa. Even with the blown fuse, the light continues to light intermittently after yje car is started. The air works, it's just not cold air.
Aug 20, 2010 at 4:36 PM
