1996 Buick Park Avenue
R1-ROBB
  • 1996 BUICK PARK AVENUE
Other Category problem
1996 Buick Park Avenue 5600 miles
My key will not turn in ignition. How do I fix. I think I need to get new igniotion? How do I remove it? I dont see any release hole Mabe I'm not looking in the reght place please help me.
Tuesday, February 19th, 2008 AT 12:40 PM
MASTERTECHTIM
  • 4,750 POSTS
Unfortunately on this system you need to disassemble steering column. First you press off the steering wheel then you use a lock plate depressor to remove the lock plate(special tool you may be able to borrow from the parts store) then remove 4 bolts holing in turn signal switch then remove key chime insert then there is a torx 20 screw that you remove then the ignition comes out. Hope this helps
Tuesday, February 19th, 2008 AT 12:44 PM
