1996 Buick Park Avenue
D16800
  • 1996 BUICK PARK AVENUE
Air Conditioning problem
1996 Buick Park Avenue 6 cyl Two Wheel Drive Automatic
My A/C do not blow on the vents, it only blow on the top of dash board, no matter if I change the possition of the vents
Saturday, August 21st, 2010 AT 3:50 PM
WRENCHTECH
  • 20,761 POSTS
The mode selection is done through a series of air doors that are operated by vacuum. When there is either a partial or total loss of vacuum, the system will default to either defrost or on some vehicles, heat. Acceleration can also have an effect on the doors for the same reason.
Look under the hood for a small black plastic hose coming through the firewall. Follow it to the vacuum source looking for any breaks, cracks or leaks. Also follow any other lines that branch off because they may go to a vacuum reservoir (storage tank) and a leak there will cause the same problem. Using a vacuum gauge to determine if you have full vacuum at any given point is the best way to find it. You can cut into the line anywhere and splice it back together with a piece of vacuum hose. Find the broken line, you found your problem.
Saturday, August 21st, 2010 AT 4:45 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I do agree with wrenchtech, I would be hooking up a hand vacuum pump to the system and checking if it is holding a vacuum, if it is you know you have a mechanical problem and not a vacuum problem, but normally these are vacuum related.
Mark (mhpautos)
Monday, August 30th, 2010 AT 1:47 AM
