1994 Buick Park Avenue Vehicle Stalls and MIL LIght is on
JEFFBRIGGS18
  • 1994 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 120,000 MILES
Have a 94 buick park ave. The transmission was slipping so we had a new one put in. After picking it up, we notcied that it still makes a slam noise when shifting between gears on occasion, and the vehicle stalls out randomly. The MIL Light was on scince we got the car 3 years ago, never thought much of it. Took the car back to transmission shop and they test drove it and said the new transmission is fine and they got the scan tool out and said the code was the cam sensor and thats what could cause the stalling and running rough intermitantly. So I replaced the cam sensor, and touched negative and postive cables together to clear memory. Started it up and light came right back on and the light test feature on the roof that tells you if one of your lights are out, they were all flashing fast even though all the lights worked. What else could cause the cam sensor code if its not the cam sesnor?
Thursday, September 23rd, 2010 AT 10:08 AM
HMAC300
  • 48,601 POSTS
Never put the negative and positive to gether to clear the mmemory. Pull the ecm fuse out for 30 seconds on your car. You may have damaged the computer by doing what you did. Have the engine scanned again as it may be something else that is causeing the problem.
Thursday, September 23rd, 2010 AT 4:56 PM
