1994 Buick Park Avenue red charging system light going on/o
15,000 MILES • 6 CYL • FWD • AUTOMATIC
WARREN WILKINS
94 Park Ave red charging system light goes on/off. Over ten years I have had to replace battery once and the alternator several times - once in last 2 years since this has been happening. Also I can interrupt or get it to go off for a bit by banging on the dash near the device. Newer battery, alternator check out good - all connections checked out good & the gauge shows at about 13-14 amps consistently.
Nov 12, 2009 at 12:48 AM
  • 110,248 POSTS
Is the belt tight? In the past, what was wrong with the old alternators that went bad?
Nov 25, 2009 at 1:27 AM
