1994 Buick Park Avenue Disable Fuel Pump
1994 BUICK PARK AVENUE
52,000 MILES • 6 CYL • FWD • AUTOMATIC
KOCHOWDA
Hi, I need to disable my fuel pump on my 1994 Buick Park Ave. In order to do so, I need the location of the relay or the fuse for the fuel pump. I want to release the fuel pressure for the fuel injectors.
We are trying to remove the intake manifold.
Aug 13, 2010 at 1:58 AM
JDL
  • 16,098 POSTS
There should be a relay center under the passenger side of dash. Pull fuse 6-- 20 amp, that should kill the fuel pump. You should be able to relieve pressure at the schrader valve, don't let gas spray everywhere.
Aug 13, 2010 at 2:20 AM
