1994 Buick Park Avenue cooling fan.
1994 BUICK PARK AVENUE
LUIS29
Engine Cooling problem
1994 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
wat wires do i onnect staight to the battery to see if my fans work .my fans dnt turn on they keep blowind the fuse,so i want to put direct power to see if they go on or not.
Apr 20, 2010 at 7:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first cut the wires at the plug on the fan side. then from there find a good ground for the black wire. next run a hot wire from the battery to the red or orange wire on the fan. if motor is OK this will turn it on.
Apr 22, 2010 at 4:14 PM
