times a week the check engine light turns on and the the rpm starts going up and down between the 1000 and the 2000
and sometimes it will die and then when when i start it again
it will run good for about 4 days and then it gives me the same
issue and maybe if im lucky i can turn it off again and turn it back on and it will go away i swap the cam shaft sensor twice because i
thought the first one was defected ...i also noticed that
the battery goes down and then it goes back up today i drove the car and it turned off and the light dim and then it turn back on and it drove fine but studdard on the way home i do have a video of it doing it the link is
http://www.youtube.com/watch?v=R7XjYDvC_P8
Tuesday, March 10th, 2009 AT 11:51 PM
