1994 Buick Park Avenue 1994 Buick Park Avenue will not stay
98,000 MILES • 6 CYL • FWD • AUTOMATIC
RIZZO146
My brothers 94 Buick Park Ave will not start. It all started when the water pump went bad which caused belt to wear a hole into power steering reservoir. I replaced water pump and power steeriing pump. When finished, car started right up, no problem. While putting tools away and cleaning up, car stalled and would not start. Towed car to garage and the crank sensor was replaced. Drove the car home, car stalled and would not start again. Replaced crank sensor again, car started right up and shut off 20 minutes later.Replaced cam sensor, and Ignition module.Car starts and then shuts off again.Fuel to rail is good.When car shuts off not getting spark from coil packs. Don't think coil packs all could be bad at same time? Car ran perfect prior to water pump/ power steering pump replacement.Any other suggestions? What else would cause no spark to plugs beside crank sensor,cam sensor, and Ignition module?
Jan 2, 2010 at 3:05 PM
  • 110,248 POSTS
Is the security light staying on? Have you checked the coil? Ignition module?
Jan 25, 2010 at 2:31 AM
