1993 Buick Park Avenue Blower Motor is good but will not wo
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
RSAND918
I bought a 1993 Buick Park Avenue at a Charity Auction. Was told by Auction staff that Blower didn't work. However my Mechanic found that Blower motor was still good. Replaced Climate Control panel.....AC worked fine until car was turned off. When car was restarted the AC Blower did not come back on...and has been off since. Where should we start looking for the problem? What sequence of steps do we need to go through to find and fix the problem?
Robert
Oct 4, 2010 at 1:19 AM
  • 75,988 POSTS
Hi rsand918, Welcome to 2carpros and TY for the donation
Check fuse no.2 10amp in the relay center and fuse no.3 30amp in right underhood fuse box if both okay the problem is either the HVAC Programmer at center of dash or the blower control module at center rear of engine compartment on firewall.
Oct 4, 2010 at 1:30 AM
RSAND918
Thanks!!
Oct 5, 2010 at 12:44 AM
  • 75,988 POSTS
You're welcome
Oct 5, 2010 at 2:08 AM
