1992 Buick Park Avenue water pump
1992 BUICK PARK AVENUE
190,000 MILES • 6 CYL • FWD • AUTOMATIC
LISA0211
While driving my car died. Under the hood: serpentine belt had come off (not damaged) and coolant had leaked out. I thought maybe a hose had come lose spraying the antifreeze around the engine causing the belt to come off. My mechanic says the water pump froze up. She proceded to show me a shredded belt until I told her mine looked fine and was in the trunk of the car. Should I trust her?
Feb 18, 2009 at 8:53 AM
BMRFIXIT
  • 19,053 POSTS
If water pump froze it will brake the belt
if it brake ,belt will come out
also suspect the idler and or tensioner
I will leave the trust issue to you
Feb 18, 2009 at 9:39 AM
LISA0211
Thank you for your input. I appreciate it!
Feb 18, 2009 at 12:42 PM
