1992 Buick Park Avenue no voltage at fuel pump
1992 BUICK PARK AVENUE
WESLEY121212
Electrical problem
1992 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 166k miles
I have no voltage at fuel pump and I have checked all fuses and they're good but after the fuses i have no voltage all the way back. I tested fuel pump with two jumpers and the pump didn't work even with a direct power sourse. Has anyone ever ran into this problem. Can anyone also verify relay location for the fuel pump.???? how can you enable the fuel pump if its been disabled?????Also if there is some sort of switch or relay please let the location of it.
Apr 9, 2009 at 9:39 PM
If you did this and hook it up properly the fuel pump is gone
Apr 9, 2009 at 10:09 PM
