1992 Buick Park Avenue engine stalling
BLAHBLAH1977
  • 1992 BUICK PARK AVENUE
Engine Mechanical problem
1992 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
why does the engine stall when brake is pressed then released?
Thursday, December 18th, 2008 AT 4:59 PM
ZACKMAN
  • 4,202 POSTS
It is coincidental. Not so much the braking, but the change in the engine rpm. Your PCM "sees" the voltage from camshaft position sensor for fuel delivery and ignition timing. If the CMP sensor is not working properly, PCM doesn't know when to send fuel to the injectors, thus stalling the engine. Have the CMP sensor checked out, you may also want to check the crankshaft position sensor and throttle position sensor checked out as well.
Thursday, December 18th, 2008 AT 8:32 PM
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
