1992 Buick Park Avenue
RHOV92
Engine Mechanical problem
1992 Buick Park Avenue 6 cyl Two Wheel Drive
my car has a loud constant rattle coming from the engine. It sounds like it could be coming from the hormonic balancer or the water pump. I have already changed the super charge and the tention pulley.
Oct 28, 2010 at 7:58 AM
WRENCHTECH
  • 20,760 POSTS
The harmonic balancer is pretty common as is the water pump also. You can mark a line across the balancer and then run the engine to see if the mark stays aligned.
Oct 28, 2010 at 8:14 AM
