The car turn off running or in stop position. This happen a any moment, hot or cold engine. No matters the automatic transmmission position Drive or Neutral. It will start again in an Hour or immedietely.
I already change the Crank sensor, idle control valve, Ignition Module but bthe problem continue. Also check the Gasoline pump ( pressure and funtional tests) and it is working Ok.
car Model: Buick park avenue, year: 1991 Mileage: 199,000
what shall I do ?
Angel velez from Puerto Rico
what shall I do ?
Feb 28, 2006 at 5:39 AM
