1991 Buick Park Avenue shutting down
70,000 MILES • 6 CYL • FWD • AUTOMATIC
1BADNINJA
after replacing the ecm, coil pack, wires and plugs, crank shaft positioning sensor and cam shaft sensor, installed crank shaft sensor with out alignment tool runs rough idle and now shuts down when reaching operating temperature
Jun 20, 2010 at 6:01 PM
INTERNETMECHANIC
  • 700 POSTS
Any applicable trouble codes? Does it restart quickly? If not, have helper crank it while you visually check for spark at the plugs, spark everywhere, use a gage and check fuel pressure.
Jun 21, 2010 at 5:34 AM
