1991 Buick Park Avenue battery gauge/transmission
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
TREYMOTTY
I have a 91 park avenue (about 73k miles), the battery gauge goes in the red zone all the way to the right, and when that happens it seems like the car stays in the same gear and won't shift up or down when I brake or accelerate...any advice on what to do?
May 9, 2009 at 1:39 AM
ZACKMAN
  • 4,202 POSTS
Start by getting the vehicle to your local auto parts store such as CSK/O'Reilly or Autozone, and have them check you electrical system: battery, starter and alternator. I suspect that your alternator is over-charging, and most system won't work properly with too much voltage.
May 10, 2009 at 10:22 AM
TREYMOTTY
[quote:14728410b0="Zackman"]Start by getting the vehicle to your local auto parts store such as CSK/O'Reilly or Autozone, and have them check you electrical system: battery, starter and alternator. I suspect that your alternator is over-charging, and most system won't work properly with too much voltage.[/quote:14728410b0]
thanks but now its changed...now the battery gauge is on the negative side nearly in the red zone with the red light staying on all the time...so does this mean i may need to get a new battery?
May 10, 2009 at 11:03 AM
ZACKMAN
  • 4,202 POSTS
Not battery. You still have problem with the alternator circuit. If the alternator is new, make sure that the belt is tight, the connector and cable are tightly attached, battery terminals are tight, and the fuses are good.
https://images.2carpros.com/forum/automotive_pictures/55316_91parkavealt_1.jpg
I would go back to the place that you got the alternator, and have them check the entire electrical system again.
May 10, 2009 at 1:50 PM
TREYMOTTY
ok thanks for the help, il go first thing in the morning..looks like i already need a jump, it already has drained the battery.
May 10, 2009 at 4:22 PM
ZACKMAN
  • 4,202 POSTS
Let us know what you find out.
May 11, 2009 at 2:56 PM
TREYMOTTY
Ok I finally got it fixed..it was just the altenator...thanks for the help
May 20, 2009 at 2:44 PM
ZACKMAN
  • 4,202 POSTS
Not a problem...
May 21, 2009 at 6:24 PM
