1991 Buick Park Avenue AC DELCO coil
152,000 MILES • 6 CYL • FWD • AUTOMATIC
AOUS
I have serious problem with the IGNITION COIL. I've changed this part for 5 times, but every time I did it got damaged. The engine won't to be start, but when I replace it with new one it start & the car goes perfect for about two weeks. I need to know what are the causes that could damage the IGNITION COIL.
some question with answers you would ask:
Does the vehicle start and run? No, you only hear the match but the engine can't start
What does or does NOT work on the vehicle? Every thing is working except the engine (lights, horn, radio, center lock...etc)
IGNITION COIL picture:
[img:9172cf2754]http://www.2carpros.com/forum/automotive_pictures/174948_DELCO_1.jpg[/img:9172cf2754]
looking forward to hearing from you...
Apr 2, 2008 at 8:31 AM
DENNYP
  • 1,824 POSTS
poor ground connections will fry a coil pack. make sure ALL of the engine grounds are good and clean.
Apr 2, 2008 at 2:44 PM
AOUS
thank you "dennyp" for your answer. I will check the connection.
Any other reason people?
Apr 3, 2008 at 12:16 AM
