Nothing happening here
BUICK
HENRY_G77
94 Buick Cenrury- The car does not want to start! Just placed a new battery, had the starter checked. Starter is gettin power at terminals. Starter does not click at all. What else could my problem be? I've looked for the fuses... can't find them. Can u please help.
Dec 29, 2006 at 2:59 AM
WICKEDLYCOLD
  • 6 POSTS
possibly be your alternator, and your voltage regulator, i'd replace both of them just to be on the safe side.
Dec 29, 2006 at 11:43 AM
SERVICE WRITER
  • 9,123 POSTS
How was the starter checked? If you don't hear the solenoid on the starter engaging are you sure it's getting power?. All connections are clean and tight?
With all due respect. the alternater and voltage regulator that is part of the alternater I believe would have to do with charging ; after the engine is running.
My logic may be just as askew!
Dec 29, 2006 at 12:15 PM
WICKEDLYCOLD
  • 6 POSTS
the alternator and regulator could be bad, and arent getting good currents from the battery.
wait, your car wont start at all?
Dec 29, 2006 at 12:48 PM
WICKEDLYCOLD
  • 6 POSTS
you make sure your positive and negative cables are hooked up to the battery good? and make sure the ground for the negative didn't come undon. i made that mistake once, and bought a new battery, cause my car wouldnt start at all, or even turn over, just like yours, and it was cause the ground wasn't hooked up
Dec 29, 2006 at 12:51 PM
SERVICE WRITER
  • 9,123 POSTS
I hate to challange or question another on auto repair as I am always learning and have been off base many times. Hopefully we got henry_g77 on the right track :wink:
Dec 29, 2006 at 1:49 PM
SCHOLLER
i have a 1992 buick regal custom and im try to install a deck, i have all the wiring harness but, took off the radio display and i cant find where the radio wiring is, i think it maybe underneath the dash compartment, could anyone confirm this for me or tell me where the wiring is. It would be very much appreciated.
Dec 30, 2006 at 7:56 AM
