92 buick roadmaster
1992 BUICK
SEEKERR10
i have a 92 buick roadmaster, it has 121000 on the odometer. the motor was replaced with a 94 LS1. When the car is idleing it has no oil pressure, when the rpm's are up the pressure is ok. I took it to a shop and was told that was normal. is it normal for oil pressure to drop to zero? I changed the oil and the pressure is ok for about a week and then it started acting up again. Could this be a bad pump or a sending unit? I was told the mileage on the replacement motor has 64000 on a fresh rebuild. It was taken out of a wrecked 94 Impala SS. I would welcome any advise or words of wisdom.
Oct 15, 2007 at 6:06 AM
MERLIN2021
  • 17,250 POSTS
Have you removed the sender and used a test gauge? pressure should be at 5psi at idle....
Oct 15, 2007 at 10:19 AM
SEEKERR10
[quote:5f899b3b14="merlin2021"]Have you removed the sender and used a test gauge? pressure should be at 5psi at idle....[/quote:5f899b3b14]
yeah, it checked out good.
i noticed when removing the sender it was loose and only leaked when motor was at operating temp. Thanks alot for the help. I hope this topic will help someone else.
Oct 15, 2007 at 11:20 AM
