Buick Lucerne Grounding Locations?
125,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DSCHWINDT
  • 51 POSTS
I suspect I have a finicky ground that is causing various electrical issues with the dashboard, air conditioning, and other systems. I looked around for grounds, but I only found one, and even then I’m not certain. I googled around for a location diagram but couldn’t find anything. I’m not too sure where to look to find this issue. Can you assist?
Apr 25, 2026 at 10:53 AM
AL514
  • 5,683 POSTS
Hello, yes we can help you out with that. What exactly is flickering on the dash? Instrument Cluster, Radio, Heating controls?
Apr 28, 2026 at 2:09 PM
AL514
  • 5,683 POSTS
Im going to post the Power and Ground Distribution wiring diagrams to start with and we can go on from there. Something you can do real quick, is if you have a 12volt automotive test light, see if you can find any fuses under the dash that are flickering like that, if you find one fuse thats is the cause it will give us further direction as to what circuit is the cause.
Here is a guide
that can help too.
https://www.2carpros.com/articles/how-to-check-a-car-fuse/
Apr 28, 2026 at 2:13 PM
AL514
  • 5,683 POSTS
Hello again, we are still working out some bugs with the new site here. So I can email you the wiring diagrams for now. Sorry for the delay, we should be able to post them here in the next day or so.
Apr 28, 2026 at 5:24 PM
