2008 Buick Lucerne Rewire power accessory outlets
20,000 MILES • 6 CYL • FWD • AUTOMATIC
DSEIBERT
  • 14 POSTS
I don't quite understand why Buick doesn't shut off the power outlets when the car is turned off.... but they don't. Everything I have plugged in...Serius radio...Car cell phone etc... I want to be turned off. I don't want to have to switch these things off myself. The outlet I use is under the drivers seat.
Question..... The fuse box is under the back seat... I am familiar with electrical wiring.
Will there be a problem to rewire?....remove the fuse and place a jumper to a different fuse that is turned off?
If so, what would any concerns be? All devices I would plug in wouldn't cause much current draw.
What fuse would you recommend connecting to?
Would there be a different way to go about this?
Thanks in advance
Don Seibert
Sep 21, 2010 at 10:04 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Don,
Thank You for the Donation....
The only problem with you doing any rewiring I would be concerned about is Voiding any Warrantee still on the vehicle.
Other than that you can use any 15 or 20 amp fuse that turns off with Ignition.
Sep 22, 2010 at 2:29 AM
