2006 Buick Lucerne heat
55,000 MILES • 6 CYL • FWD • AUTOMATIC
BIZIBOY
heat comes out only when rpm s are up like normal driving at idle there is only cold air can you help?
Oct 22, 2010 at 3:41 AM
GMTECH
  • 537 POSTS
When you engine speeds up the water pump is working faster to push the coolant through. You may have a blockage in your heater core so only higher pressure can go through. Back flushing the heater core is a good start. Disconnect both hoses and flush it with a garden hose until you think you have all the crap out. The top up with new coolant and try. Flushing the whole system may not be a bad idea if you have never done that yet.
Nov 8, 2010 at 6:08 AM
